Purolator moving away from louvers?
VA
I purchased (at a Central Ohio Menard's location) a Purolator One filter (PL14459) that looks to have been manufactured in Sept. 2023 that has holes in its core as opposed to louvers.
Has anyone else noticed this change?
Those appear to be well made from the limited scope we can see.
The sad thing is that louvers aren't hard to make well; not really any more difficult than holes. They are either strip stamped in a progressive die, or run on a continuous roller die. (Progressive dies are more common). Either way, it's just a matter of adjusting the shut height and adjusting a few things. Typically, poorly formed louvers are a sign of a total lack of understanding the press set-up and/or a lack of any kind of quality commitment. The only other thing that can cause louvers to not be fully formed is a severly (and I mean horribly) worn out die.
Once the perforations are made, they can then roll-form the strip into the spiral tube and cut to length.
Any company which wants to make good louvers can do so fairly easily in a high-volume manufacturing press with just a moderate amount of effort. The crappy examples we've seen time and time again really do show a total lack of concern at the manufacturing level.
Topic Puro filter 9688 equivalent used on many Hyun/Kia vehicles where the OEM is made Mann&Hummel in S.Korea. M&H also owner of Purolator (and Wix.) Below is Napa Gold/(Wix) equivalent 1334, same design as topic. So, short answer to topic query, no.
