While we dont know if this new 'truss' will be used or not,Purolator is going to a lot of trouble if they dont.
They seem very determined to make changes to their filter and this is just one example of such.They are seeking a patent for a new bypass/ADBV combo and according to their description of their new filter design,it will not have metal parts in it,that includes the end caps.
While it may not say this in so many words,the very description of the design would most likely do away with metal because they are trying to get away from certain glues and the oven that is needed to cure those glues.
If you take the heat of the oven from the filter sealing process,that leaves few choices in sealing the ends of the filter element.Those choices most likely would be to glue both ends of the element with a sealer and not use end caps as some filters or they could make a filter with a fiber type end cap and ultrasonically weld the end caps to the element.
There was also mention in a post that if Purolator does go this way that it would be tested.That is true but Champ tested their design too and it has problems even at this point and they have been on the market for quite some time.
Someone also mentioned that WIX has a location close to where one of the Purolator designers is from.WIX has already started using a Bypass/ADBV combo is some of the filters it makes.I have used one and have another one to put on.
WIX says that the new valve is in their Pro-Tec filters but the new valve is in other filters as well.
WIX Combo
While we cant say what WIX will do,this could be a first step to a filter redesign by them as well,especially for their private label filters.
