Thinking of switching from the OEM Toyota filter to the PureONE on my 2005 Tacoma V6. The PureONE for it is the PL10241.
I noticed this particular filter has a different design on the bypass valve ... it's in the dome end (labman's favorite
) but doesn't look like the usual flat "45 record adaptor" flat spring that Purolator uses on other filter models.
The bypass in the PL10241 (and some others I've noticed) sticks down inside the center tube and has a square U shaped bracket that is spot welded to the top metal end plate of the element. You can kind of see it in the photo below.
Does anyone have a photo of a dissected Purolator showing the details of this bypass valve design? I'd like to know more about it.
