Purging a current grease, for a new?
Maryland, 21770
Hello to all.
I would like to know if there is a cartridge for the typical grease gun that is available (cheaply) to "Purge" the current grease in a fitting/component that is neutral to the "NEW" incoming grease one wishes to use, (compatibility) question?
I simply don't want to use $10.00 + grease cartridges to purge to a new grease type? Understand?
If not as above, then what cheap method is available?
Please do not suggest disassembly and cleaning of the object component, this would be stupid!
there is no neutral grease. you would need a cheap version of your preferred grease(same base type)
also simply overfilling wont really purge the majority out in certain applications.
