I might use the Puralator PureOne with Mobil 1 SS 10W 30 this weekend. What do you guys think of the PureOne filter?
Same thing happened to me with the Bosch Premium..slooow rise in oil pressure at start-up and a warning beep on the dashquote:
Originally posted by unDummy:
I tried using it with two different cars and had serious low rpm noise even when warm. Nothing like changing a filter in the auto parts store parking lot with the cheaper Purolator and not having a problem. Never bothered with it again.
Could be bad luck, failed engine or filter bypass, or a defective excessively restrictive filterDidn't try to debug the filter issue any further than swapping and trashing it!
Same here Greaserquote:
changed the Bosch out for a Premium Plus and never looked back
Your description of why a by-pass valve opens is correct..as for the PureOne...never used one..the Mobil is a very well built filter...it just gave me a lag on my oil pressure gauge and a warning beep once in a while...using Purolater Premium Plus filter now...no more problems.quote:
Originally posted by SilverStreak:
Any more opinions on the PureOne before I switch. Teh K&N has worked fine for me, no probs on really cold starts or anything. I want a more efficient filter. Hopefully the PureOne flows better than the Mobil filter.
I have one question, can anyone explain when a filter goes to by-pass mode. Is this when flow is retricted and so the by pass valve opens up in the filter to allow flow?
