For conversation only......
I have read and seen some info that claims in modern gas stations with equipment in good working order do not give you all the gas you are paying for...
The faster the pumps the less fuel you're getting.. many claim to take the extra 30 seconds and pump slower... Personally I can't stand those super slow pumps but......
There's some logic in principle but it may not result in significant differences in accuracy.
Petrol pumps have traditionally used a positive displacement type of flow meter. PD meters must have some small leakage (unmetered flow) so that at lower flow rates the leakage represents a larger percentage of the total. You would need to know the exact specifications of the meter to calculate whether pumping fuel at a slow rate had any meaningful benefit over pumping at a high rate.
For example the leakage rate through the meter might mean that it didn't record a flow rate of one drip per second but that flow rate is so low that it has no significant effect on overall accuracy at practical flow rates.
