Pump Rub - Transfer Case GM Products
BC, Canada
Has anyone had this happen to them?
http://www.merchant-automotive.com/transfer-case-pump-upgrade-kit.aspx Just wondering if I need to be proactive on this. I don't consider myself hard on the transfer case, engagements are usually done while stopped even though engagement on the fly is possible. No towing in 4wd etc. Vehicle is a 2006 GMC K1500. The factory OEM steel clips that are there now look like the right solution, not sure I need the aftermarket part.
229
Mid Atlantic
You need the aftermarket part. It has a wider contact area that distributes the force out and has less potential to break than the factory setup.
Cleveland, GA
Originally Posted By: marc1
Has anyone had this happen to them? http://www.merchant-automotive.com/transfer-case-pump-upgrade-kit.aspx Just wondering if I need to be proactive on this. I don't consider myself hard on the transfer case, engagements are usually done while stopped even though engagement on the fly is possible. No towing in 4wd etc. Vehicle is a 2006 GMC K1500. The factory OEM steel clips that are there now look like the right solution, not sure I need the aftermarket part.
Doesn't matter if you never put it in 4wd. It will happen over time.
NC
Ive read alot on this subject. I believe its a more pronounced problem in 2500 trucks. It looks like a somewhat simple repair, if you can do without a truck for a day or two. I have the NP261 in mine, I just keep an eye on the area where it will potentially leak. This is something I lose sleep over!
