Following on from THIS thread, the weird brake pedal is fixed. But now seem to have a new issue.
The symptom is a pull to the right under light braking only. When you brake moderately heavy or anchor on, it pulls straight and true.
This is following work I did to the car on the weekend. This included new ball joints up front, new drop links and I re-bled the entire braking system while running the ABS pump.
I have two theory's
Theory 1 - I've pulled some air or grubby fluid out of a passage within the ABS pump into a line somewhere? I pulled 500ml (half a quart) out of each corner starting with the rear left side (furthest away from the M/C) and finishing with the front right side (closest to the M/C)
Theory 2 - Geometry issue caused by the new ball joints and generally having the suspension apart?
Anyone got any other ideas? Need to get this sorted this weekend as it's due it's annual MOT in the next week or so where braking etc is tested.
I have two theory's
