PU 5w30, 6900 miles, 98 Corvette
Patman
Staff member
Guelph, Ontario
Here are the latest oil analysis results from my 98 Corvette
Analysis by Wearcheck Canada
6900 miles on oil
Apr 24 to Nov 28 (7 months)
122,000 miles on the car
Pennzoil Ultra 5w30
Fram Extended Guard oil filter
Vararam cold air kit (with a cotton gauze filter)
LS1 5.7L V8 engine
7.5 qt oil capacity
no makeup oil added
(it was down 1.25qt at the end)
Oil life monitor was at 2%
Iron 13
Lead 2
Aluminum 5
Copper 1
Chromium 1
Tin 1
Silver 0
Titanium 0
Nickel 1
Silicon 14
Potassium 2
Sodium 6
Boron 199
Moly 54
Barium 0
Calcium 3094
Sulfur 2491
Magnesium 17
Manganese 1
Vanadium 0
Beryllium 0
Cadmium 0
Antimony 1
Phosphorus 696
Zinc 920
Fuel 0
Glycol 0
Water 0
Oxidation 82
Nitration 64
Sulfation 75
*note, the above three values are not percentages*
Viscosity at 100c 11.2
Originally Posted By: beast3300
Looks like a great report, but why is viscosity@100 showing 11.2??
I believe that Wearcheck shows the viscosity a little bit higher than other labs. I've consistently gotten readings of 10.9 to 11.0 when I used Pennzoil Platinum 5w30 for instance.
Originally Posted By: daman
Very nice report Pat wear looks great,how did PU compare to your PP runs?
i like this oil, Insolubles?
Wearcheck doesn't test for insolubles.
Wear was a tiny bit better with PU compared to PP, here is a comparison run of my last OCI, which was also 6900 miles:
Code:
PP PU
Iron 16 13
Lead 2 2
Al 8 5
Copper 1 1
Chrome 2 1
Tin 1 1
Nickel 0 1
Silver 0 0
Titanium 0 0
that was one/1st run with the PU? doing more to get a better average with the PP?
Yep, this was my first run with PU, but I will be doing many many more, as I plan on running this oil for quite a while. So it will be interesting to see if the wear numbers change with subsequent intervals or if they stay relatively the same.
Very good report, seems like PU can be used in your Corvette few thousands miles more.
I'm glad I ordered 4 cases PU (2 cases 10W30 and 2 cases 5W20) from Amazon when they had it on special low price of $17.xx and $19.xx a case couple weeks ago.
Good, i did pick up a few jugs back when on sale to compare it's cleaning ability's to M1,it's a fine oil.
How do you plan on comparing the cleaning ability between the two oils? Thanks.
PU is a good oil, and definetly made a difference here - Al came down substantially - something I'd been 'worried about' on your engine! :P
Well the plan is on next OC in the kids sunfire to switch over to PU it was neglected when we got it since then it's seen Mobil 1 High Mileage and is cleaning up pretty good for the time/mileage driven so far,sooo at the change time i'll record the mileage and drive it the same and compare at the end how fast or slow it's been cleaning..
I fixed you signature line for you, Dan...
"Usually"..Mobil 1
"Usually"..Mobil 1
it's just a test,not jumping ship...lol
When I saw that lower aluminum number I immediately thought about you!
