A friend of mine nursed one of those along for years with a blown head gasket. Every time he would drive it he would open the hood and pop the radiator cap lever so it would suck coolant from the over flow bottle back into the radiator.
I don’t blame them.A friend of mine nursed one of those along for years with a blown head gasket. Every time he would drive it he would open the hood and pop the radiator cap lever so it would suck coolant from the over flow bottle back into the radiator.
Walt's Aztec though lol. Even worseRemember when Skylar gets Walt Junior a PT Cruiser in Breaking Bad? The look on his face when he saw it was priceless![]()
Naaah. At least the Aztec implemented ideas. The PT cruiser is pure poor aesthetic taste, nothing else.Walt's Aztec though lol. Even worse![]()
Its a disposable vehicle with an interferance engine with a rubber internal wet timing belt that has aged out. Unfortunately it's about two thousand dollars of labor to replace that belt. People commonly won't do the belt becausd of the labor cost. It breaks and pistons hit valves, then it's not worth fixing and ends up in the junk-yard.
Back in the day, those belts broke between 80,000 and 85,000 miles almost like clockwork. But age has a lot to do with it also. A 25 yo belt is trash, even with only 5k miles on it.
It's the definition of a disposable vehicle. Worth two thousand tops, drive until it grenades because the belt broke, pull the tires off and scrap it.
My brother had one. When it had 70 K something miles on it, I warned him about the belt and told him to have it done at 80,000 miles. He did not. At 82 K he had his family in it with his son driving, accelerating on an on ramp in Erie the belt went. It was not worth fixing. A mechanic gave him $400.00 for it ( because it had 4 new tires on it ). That mechanic did fix it and sold it.
I don't know where you dug this story up, but the 2.4L engine's timing belt is not "wet" (unless you've got horrifically bad cam seals), nor is the engine an interference engine. I've done several timing belt/water pump jobs on these vehicles and other 2.4L-equipped cars and vans, several of which suffered broken belts. Take it all apart, change the water pump, line it all up, re-install new idler, belt, and tensioner. Done.
It is an expensive job - but not a difficult one. Any DIY-er can handle it.
And in spite of all the negative comments, the 2.4L DOHC engine is a fairly robust unit with pretty decent longevity. I've had three PTs myself and just sold my 265k-mile Caravan with the very same 2.4L engine, which I bought brand new. Great drivetrain. So good I just bought a used low-mile 2007 Caravan with the same 2.4L.
It said valves hitting pistons is more likley if the RPMs are high when the belt fails.
Those sellers are just by nature always extremely high. They do have overhead a home / private seller does not have. Still they most always list way over priced "asking" numbers.In order to make a value judgement on this car, one needs the asking price. The car is being sold by a high-dollar classic car dealer, not the original owner, and the asking price is $16,900:
https://www.vantageauto.com/inventory/chrysler/
As cool as a time capsule this may be, the ask is far too high. As a first-year car - with most of the early run selling at full MSRP - this loaded Limited model likely cost around $21K.
Due to the sheer number of these made between 2001-2010, they have never achieved collectible status...and probably never will.
For a nice driver like this I'd give no more than $8-9K. It would almost assuredly require some reconditioning costs to replace perishable items like tires, belts, hoses, and probably most of the engine fluids. All pretty easy to do.
Add the dealer's $1050 "doc fee," and this price is in the stratosphere...getting close to the original MSRP. Hard pass.
I looked it up on GROK, your right about the belt not being in oil, and while it does have indents in pistons for valves, it may still have valves hit pistons depending on when / wear the cam stops. It said valves hitting pistons is more likley if the RPMs are high when the belt fails.
When my brotherd PT grenaded, his mechanic did say it needed a new engjne.Can we rely on first hand experiences and knowledge and not grok?
I'm impressed - had always assumed any DOHC engine would have to be an interference engine.That's the problem with the interwebs. Too much data, and much of it wrong.
The 2.4L pistons have valve reliefs on top; there's basically no chance of valve-to-piston contact. The only possible interference - and it's a longshot - is valve-to-valve. And the only chance for this would be if the engine was screaming when the belt breaks (i.e., someone beating the snot out of it). I've never seen this once, and have worked on a lot of 2.4s.
Yep . My Mom had one . I hated it . Underpowered , noisy , but good on gas . She beat the hell out of it .What I remember about the PT cruiser is that a lot of gray hair women drove them back in the day around here.
