Is there a difference between Sierra, Amsoil, and Evans coolants. Aren't they all PG? Amsoil recommends mixing with water but Evans does not. Why? Does the engine run cooler or fight detonation better with PG? Thanks.
I understand the logic here but I disagree with the final conclusion. In Florida with straight water you might technically have a greater cooling system heat transfer capacity (due to the lesser viscosity and greater specific heat) but you would run a severe risk of the system boiling over. Even with a 15 PSI cap the water would boil very early with no EG or PG in the system and all modern cooling systems are sized to allow the coolant to get well into the range it would boil without a 50/50 mix in it.quote:
Originally posted by Winston:
If your car lived in Florida you would be better off with straight water and a corrosion inhibitor. But, you better not drive up north in the winter.
My memory must be fading as I thought that ethyleneglycol had a much higher specific heat than propyleneglycol making it a better heat transfer agent...am I mistaken in this recollection...???quote:
As far as helping with the cooling capacity, water has a higher specific heat than PG and PG has a higher specific heat than EG.
