Originally Posted By: 86cutlass307
Has anyone ever protested a dramatic hike in their primary residence property tax? If so, what did you take with you to the hearing...it seems a little one sided to me. I have done no renovation, expansion, etc. Thanks in advance
What is the law in your jurisdiction? Here, there is a legal mandate that taxable value must be brought in parity with assessed value, so property taxes will increase annually at a specific rate until this is achieved. No amount of protest will alter this. Of course, properties will be reappraised in the meantime, so the goalposts will always be a moving target.
Property owners generally are competent to testify to the value of their own property, but in the absence of some special knowledge or experience are generally incompetent to testify to real estate values.
You could have a realtor friend do a drive by appraisal on your property, and if it looks like there is a real disparity between the actual and assessed value, a real appraiser should be engaged.
