- Joined
- Sep 17, 2025
- Messages
- 332
Proper/correct negative battery post grounding wire Gauge? ( I'm in Canada with a '06 Nissan Xtrail. A 2.5L /4 cyl. engine with AWD &4 speed auto. Same engine and transmission for the 06 Altima).
I think I saw on the Nissan parts order site it is a 4 gauge. But the OEM original has a middle copper connector that a 10 mm bolt (in middle of the cable) that bolts to metal surface behind the battery. One end connected to negative battery post, other end bolts down under the metal battery tray to (I think transmission).....I did the big three upgrade, but I only used 10 gauge wires. I was at my local Nissan Canada Dealership part's department last weekend, they want $134 plus tax for OEM negative battery cable!!!
Anyways I removed my negative battery cable two weeks ago, only to inspect for corrosion and clean up all bolts related to this cable, the bolt hole surfaces were sanded free of paint/dielectric grease added to the surfaces. I reused the cable lug/sanded both sides of the loop. Anyways, everything works good, no issues, but that OEM negative ground cable has that greenish corrosion one one end that goes under the battery tray. Which I guess is normal for a 19 year old vehicle with possible original ground wire ( I bought this truck in 2015 /I might be the third owner).
So a few questions....should I replace the OEM ground wire with 2 0r 4 gauge? Reason I ask is because the OEM new is $134 and I can go to Home Depot and buy gauge wire by the size and length/meter. Much cheaper . I can buy a pair of 4 gauge copper lugs for less then $5. Home Depot:
$12.37 / M..........or my local Walmart has a 24 '' negative battery cable for only $8-9.
Southwire . Another store has a 4 gauge- 29 inch battery cable with lug on one end and negative battery post connector. $16. Regardless, I need to modify and cut the sheath in the middle of the cable and add a loop lug for the ten mm bolt . My confusion is what size Gauge is needed and how to correctly install my own home made wire from battery post to middle and finally to under the battery tray. Also, should I have gone with bigger gauge ''big three'' wires'' then the 10 gauge I used. ?
$12.37 / M
Southwire
Model # 11298798|Store SKU # 1000714539$12.37 / M..........or my local Walmart has a 24 '' negative battery cable for only $8-9.
$12.37 / M
