Thanks! My only concern is the pink long life coolant only comes in 50/50. Could I use something else like Peak long life universal or should I stick with the pink HOAT coolant? It never gets below 20 degrees where I live so would a higher % of water be ok?
The good news in the era of multi color coolant, is that most systems dont have any iron in them anymore, and the systems usually stay clean and clear, if you dont do something improper (like mixing in silicated antifreeze), dont run too long over, and dont have a breach (head gasket oil to coolant), it should stay relatively clean and clear.
With that being the case, the approach to drain the radiator (or remove the lower hose), and then refill is appropriate. Ideally the vehicle gets operated to open the thermostat, and blend the new coolant with the old, and then is drained another time or two. Doing so with 50/50 keeps the ratios correct, and gets you somewhere between 25-66% replacement. After the five year mark, as I recall, the replacement period drops to something shorter because of that reason.
That's just it, I don't know what kind of coolant is in there now and the coolant in the radiator looks bad (brownish orange)
Brownish orange is strange to me because I believe thats an aluminum head/block engine, and an aluminum radiator in there.... So the issue could be additive fallout or an improper mix.
Id drain the radiator, and then fill and drain it with water once or twice, just to get any loose junk out. Id then do drain and refills from the radiator or lower hose and monitor it. Id do a few extra like this over the next few months, and watch if the coolant clears up. If something goes bad, removal and flushing of the radiator may be necessary, or else if something is worse, the service would include opening block drains and the thermostat, and then the system would be able to be evacuated before putting it all back together...
