Project Malibu resurection: Death and rebirth
Iowa
I bought a 1998 Malibu with a 2.4 last summer from a customer who didn't desire to fix it up after the engine began making some pretty serious lower end noise. I gave him scrap yard price- around 200.00 and drug it home until I could fix it. Well, that time has come. I want it to replace my wife's aging and soon to be ailing 1995 Grand Am, which I gave a new lease on life with a budget minded refreshed 3.1 (also poached from a customer)- can read about it HERE. The Grand Am was intended to last another 70k miles or so, or until something major happens to it. Well I've been getting leery of it so I'm upping the time line on the 'Bu...
In spite of the terrible lower end knock, it started easily and drove onto the trailer, then off again to it's resting place. I've moved it around a few times over the summer, then finally back on the trailer to haul it to the shop where I off loaded it and drove it inside. It was there that I began inspecting it for external damage because there was a trail of oil following me... Hoping for better than a hole in the block, I was rewarded by finding the oil pressure sending unit to be leaking BADLY. Pretty common on these and likely the cause of the Bu's untimely demise. I considered buying a reman engine, but that would be at least 2200.00 from my sources. Used is a gamble on this one and would need a certain things before even dropping it in the car. The nearest one was a 100+ miles away and 600.00. So by the time I bought fuel for my friend's truck and lunch for both of us, I'd have 700.00 wrapped up in it and still need to replace the oil pump, water pump and timing set.
Here it is, just after I started working on it. I took the photo as an afterthought- you'll notice that this will be a common theme on this project. Sometimes I get started and forget to take pics as I pass various stages.
Here I've got some things taken off and am ready to really dig in!
A bad pic, but here it's almost ready to take flight via the engine hoist.
So once I was able to get the engine out, I took the pad off, expecting the worst. What I found was pretty impressive!
and YIKES!!! Yes, that's bearing... Rod bearing to be precise.
I took the balance shaft assembly and oil pump off so I could get to the bum rod. The nuts were suspiciously loose and the journal was hit pretty hard.
I called a machine shop who told me that they could do the crank for less than 200 bux. A reman crank and bearings is 500.00 through Rock Auto. Hmmm. Tough choice.
I'll have some more pictures in a little while- as I've got to go for now. They'll be interesting for sure...
Nice that it's not covered in rust like my friend's 1999 Malibu. It ran for a long time though with very little maintenance, 200k when it was in an accident.
How many miles on the car?
Unless the shop has a horrible track record or the crank is beyond hope, I would just turn the crank, buy some new bearings and save a few hundred in the process.
To be honest, I'm a little fuzzy on the actual mileage. I think it's around 174k though- really, it's in decent shape for the miles, and has at least 100k less than my wife's current ride.
I know the interwebs is a terrible place when it comes to conveying emotions or inflection, but there was sarcasm in it. In fact, the crank is over there now, done. The machinist said that it was really close to cleaning at .010", so I'm sure he took it .020" under. Really, except for that one journal, the crank looked really good.
Originally Posted By: CHARLIEBRONSON21
The space in there makes me jealous a bit
I just wish that we had the whole building to work out of. It looks big, and at 48 x 80, it's not small, but half of it used as cold storage. What you don't see in there is the BIG 4WD tractor just out of the frame that's taking up a pretty sizable chunk of floor space.
So to save this engine, are you going to hone the bores with the engine in the car, and re-ring the engine, or are you going to have your machinist rebore the engine, and have you fit oversize pistons and rings?
Now for the rest of the pictures that I have taken so far.
This is another rod journal- really, not too bad for 174K miles.
Of course, the first thing I did was to pull the wounded piston and rod out. It is the only one that can be removed from the bottom. Since there was no bearing the piston was able to come in contact with the crank. Rod is toast also. See anything wrong with the cap???
I was going to just throw a crank in it initially, but after seeing that it needed a rod and piston, I decided to go all in and toss a set of rings at it too.
Once I got the engine completely stripped down, I was better able to inspect the cylinders. No detectable ring ridge and still some cross hatch. The wounded piston left it's mark (literally) on the cylinder, but nothing serious. What I didn't get a photo of is after I honed it. Once I started running the hone through it, I was able to see that there was a very slight ridge. A few minutes of light work with the ridge reamer took care of most of it and I was able to get the cylinders honed. I'll probably have the machine shop surface the block and maybe go through the head to... Not sure yet.
Here is what it looked like before I sent most of it off to be cleaned... I'll do some of it on house- like the pistons and some small parts.
I've made some purchases through Rock Auto and Ebay, as well as the machine shop, including rings, a piston, connecting rod, full gasket set, timing set with GMB water pump, head bolts, O2 sensor, belt, tensioner, thermostat, t-stat housing (water neck) and a few other things. Close monitoring of Rock Auto's shipping (thanks to the warnings of sharp eyed BITOG members) made sure I didn't get bent over the barrel as well as comparison shopping and discount codes helped keep the cost down.
Originally Posted By: gregk24
Ouch, very common on these old GM 2.4's though.
Any idea of the actual cause of it? Some light reading on the interweb suggested low oil levels would do this.
Greg takes any opportunity to bash GM he can, and really doesn't have a lot of automotive knowledge. Any engine you run low on oil is going to spin a rod, and I think you were on the right track with the bad sending unit being partially to blame. Driver probably never checked the oil.
Thanks for the pics, can't wait to see the progress!
There is a vent in the passenger side of the trunk, behind the carpet, that tends to leak. Check the jack and spare tire for rust. It is difficult to stop the leak, apparently the rear tire sprays water into the vent.
I never did get it to stop leaking on my daughters car.
I avoid ebay for engine parts because the seller might do a rebox. And unless the project that I work on has to time table, I'm starting to avoid RockAuto. Most parts that I now order from RockAuto on Saturday or Sunday don't make it to my doorstep for almost a week. They are also starting to push the "DNJ" brand of engine components instead of the older name brands.
Have you ever used Northern Auto out of Sioux City? (Google them) They have a nice catalog they can mail you, a usable web site, have excellent phone service (just talked to one of their guys yesterday), and they ship promptly. They also use name brand parts on their rebuild kits.
i love these threads, keep us updated!
GMB is a very good brand, i've ordered a few timing belt kits with GMB parts and they work well.
Terry, thanks for the tip! I'll be sure to look into that.
I'm kind of rolling the dice on this one, hoping that the DNJ products are just major manu reboxes. Looking at the file photo of their full gasket set makes me think so... Time will tell.
Thank you for the heads up on Northern Auto, I had heard about them and have since forgotten. I will keep them in mind for future purchases.
Will do! I too have heard good things and had a few good experiences with GMB, and hopefully this won't be any different. Especially since it is timing chain driven. I sent a message to the seller on e-bay asking the country of origin- the reply was Korea. Certainly better than China...
Wonderful project, please keep us updated on your progress.
I have a question.
What would be your approach in dropping in your engine?
Supposing that you assemble the long block outside, with the 2 lifting eyes tightened onto the sides of the cylinder head. In that case, I've often wondered, because of the weight of the short block, could there be too much stress (I mean stretching in the wrong direction) exerted on the head bolts and their threads? So that the clamping force/pressure between the head and the short block is significantly (and possibly permanently) lessened?
I'll be keeping an eye on this thread. Brings back memories of the 2.4 I had in a 1996 Sunfire GT. This was back when I didn't go over 3k miles in an OC, so I never had a problem. Traded it in with 165k on it and still ran great.
Is this the first 2.4 you've had? Don't know if you know of the problem areas or not, but the plastic piece that the ignition coils are bolted into is a weak point in the ignition system. Also, the thermostat is in the stupidest place possible. I had to replace the water pump on mine, and it was a chore to get at it with the engine in the car. Same with the thermo.
I love threads like these. It's an adventure of what you are going through! Good luck!
I never really had problems with Rockauto. Although it has been a long time ago when I ordered an actual part for my nissan, an upper timing chain tensioner and it worked great. Although i did order a gasket set that was slightly off and had to get one from bennett auto supply instead. Otherwise, I get my airfilters through them.
