Wasn't sure how to title this. I posted something similar to this a week ago, but not sure if it made sense or not.
I was wondering what the typical progressing of using synthetic is once you have exceeded the 100K mile mark and perhaps the eingine beings to seep oil out the gaskets. Those who have never had a leaky engine while using synthetic need not reply to this. This isn't about yout. However, his is about the many people I have spoken too who have used synthetic in their engines since new and developed oil leaks later on down the roard perhaps due to engine designe or gausket design or simply, age of the gaskets. If it is too costly of a repair and not worth fixing because it's not causing any problems, have you continued on using synthetic and topping off as needed, or do you revert back to the Valvoline Maxlife or Castrol HM oils at that point? It sort of seems like a step backward to have to go from using synthetic back to a conventionl HM blend. But wanted to know from others what they have done. I'm going to be running M1 in my van for as long as I can possible do it, but wanted to know what I'm suppose to when its time to go back to conventional if I ever had to.
