Product similar to Wesley’s bleach white
Nowhere NM
The title says it all, I need to clean my tires and car wash soap isn’t getting it done. The WBW was great back in the days of white wall tires.
Thanks
Smoky
What’s wrong with the current Bleche-Wite product? Branding is now Black Magic instead of Westley’s.
yeah. Blech-white went through a time when the weakened the formula and it got lots of bad reviews, i went to meguiars hot rims wheel and tire cleaner then when i ran out i tried blech-white again and it worked just as good, same brown scum running down the tire after spraying,
id say give it a try. its cheap and readily avaialble.
I have a sneaky suspicion that RV black streak remover, and Westleys bleche white are the same. They smell the same and ive used them interchangeably and could not tell a difference.
I use bleach white, or Whitewall cleaner from superior products. It’s reasonable and performs. It’s also available at O’reilly’s by the gallon.
Bleche-Wite still works great for regular tires. Or any good APC. There are several out there.
