Hi:
The wife's car is a 99 Ford Contour with 95,000. I've been current with the maintenance. Fuel pump has never been replaced. I originally thought the problem was the battery, but checked it and its good. Since I can’t figure it out, I took it to our mechanic yesterday and he hasn’t been able to duplicate the problem. He doesn’t want to replace the fuel pump and find out that wasn’t it (Thus wasting $300). My guess is the fuel pump, but he also mentioned it could be a fuel pump relay.
This is how she describes the problem:
car makes a wet sound when trying to start it. Sounds like it catches then sputters to nothing again. Last time it happened, someone sprayed ether repeatedly into area under air filter, kept trying to start it and finally did after several attempts. Car had been running fine about an hour previously.
The wet noise she mentioned sounds like the fuel is not getting to where it is supposed to go. Of course the car starts up every time when I try. Problem started on Sunday.
Any guesses??
Thanks!
Any guesses??
Thanks!
