Originally Posted By: Tegger
Originally Posted By: coopns
Recommendations for the door hinges to prevent rust? Best type of spray?
White lithium grease is often used.
I normally use this, though if there is a squeak or similar I will use wd40 to clean things out, remove all the old grease and muck then redo with more lithium grease, very handy in the aerosol cans, I normally have one in a cubby hole in the boot along with some wd40 or similar product.
