Pressure washer seals
Golden Meadow, LA
Simpson 3000 psi pressure washer, I notice after shutting it off that it leaks from behind the pump, grayish watery mixture. Is this the seal between the engine/pump? Is it fixable? Thanks for any info
Found the issue, this seal on the front of the pump is bad. Do yall recommend a new pump or attempting to rebuild this one? No doubt it got oil water contamination.
Simpson should at least have parts available. Seals are dirt cheap. Pump is most likely fine. I had a detailing business and pump had a small leak for like 10 years. I ran some Lucas to slow it down to near non existent. 100s of hours on that thing. Now it probably gets 1hr a year. I gave up the business in 2020.
