I have a Troy-Bilt 2200 PSI pressure washer. I got it in 2005. I haven't used much and probably not at all in the last 5 years at least. The engine starts easily and it runs good, even on the original plug. The oil was changed previously and it's still golden, not black. However the pump appears to be putting out water pressure at a reduced rate, not enough to power wash with. What makes these pumps totally fail or diminish in output? Can they be rebuilt cheaply or is it best to by a new one for $100-$144, an AR or the original FAIP. The FAIP appears to be the more expensive one.
Whimsey
Whimsey
