I bought one for $15 hoping to use it to clean some of the dirty areas of my home's wood siding. I have a 8-10 year old pressure washer I bought at Sams.
The foam blaster connects after the trigger using a 1/4" quick disconnect. My wand has no quick disconnect. Not sure I can even get the nozzle section off to install a quick connect.
The soap for the foam blaster says it produces a thick & clingy foam.
I do not want to buy a new trigger & wand assembly just to use the foam blaster.
If I cannot figure out how to easily and cheaply connect the foam blaster to my current wand, do you think it would produce thick and cling foam if I fed the soap through the normal chemical intake?
