cooksillustrated.com ratings were from Jan-2005. Here is the rest of their ratings:
RECOMMENDED WITH RESERVATIONS
Magefesa Classic 8 Quart (PG 04008):
-- $85.00
-- Spanish manufacture
We liked the Magefesa for its quick steam time (time it takes to reach a steam), good locking handle, and consistent performance under high pressure. As with the Fagor, the indication of high pressure is a "gentle steady flow steam," However, we found the quick-release switch to be too flat and jerky to turn--it also gets very hot. The instruction manual is also wholly inadequate: unclear and with translation errors, it also contains only a handful of recipes.
WMF Perfect Plus 8.5 Quart (#0793149300):
-- $197.99
-- German manufacture
Given its high price, the WMF should be perfect, and it comes close. Its detachable, easy-to-clean handle locks easily, it has a well-marked valve that indicates low and high pressure, and it has an easy-to-handle quick-release valve, which directs the steam well away from the cook. Still, many of the cooks in the test kitchen so disliked the low hum the cooker emits at high pressure that they said they would never want it in their kitchen.
Kuhn-Rikon Duromatic 7.4 Quart (7 Liter) (INOX):
-- $169.00
-- Swiss manufacture
We found two problems with this cooker, neither of which we'd expect given its high price. While we liked the valve that clearly indicates both high and low pressure, we were uncomfortable with the fact that the handle had no audible or manual locking mechanism -- although it is locked when the handles are correctly positioned over each other. Second, while several of the cookers suggest running a pot under water as an alternative method for quick release (as opposed to slow and normal release), in the Duromatic this is the only option the instruction manual gives, (although some models do have automatic pressure reduction functions). Further, the maker says that only the rim should be rinsed, and manipulating the hot, heavy pot in the sink is very awkward.
NOT RECOMMENDED
Presto 8 Quart Stainless (#01370):
-- $87.49
-- U.S. manufacture
The best feature of the Presto is a valve that indicates when all the pressure has been released. Otherwise, its handles are too short and, although advertised as "stay cool," we found they got hot, unlike the long handles on the other models tested. The bottom also has a slight tendency to scorch. Finally, more than any other model, this one spat water in different directions.
Innova Stainless Steel 8 Quart (#42008)
-- $89.99
-- Chinese Manufacture
We can't recommend the Innova for a variety of reasons. The instruction manual is so unclear that no one in the kitchen could figure out how to remove the detachable rings that control the pressure. The pot has a number of small, removable parts that must be detached with every use, including the pressure regulator, which got very hot. Under high pressure, this cooker spat steam straight up. It was also difficult to determine how much pressure was in the pot -- a "slight rocking motion" of the regulator is supposed to indicate maximum steam. Further, the only way to test whether the pressure was gone was to tilt the pressure regulator; if the pressure wasn't gone, the cooker would spew steam, which could easily burn your hand.
