Originally Posted by dx92beater
Originally Posted by Trav
Originally Posted by CT8
Sand paper and or scotchbrite!!!!!
Never use Scotchbrite near an open assembled engine it ruins engine bearings. No oil filter made will remove the microscopic particles, they roam around infinitum in the engine damaging anything the come in contact with. I wont even use a powered disc type under the hood, sandpaper isn't much better.
The only thing I would try is white vinegar, cover the deck with newspaper soaked in the vineger and cover with a plastic bag, let sit overnight and use a small brass brush and wd40 to remove the scum left over.
You do mean a brass hand brush not a power tool right?
Correct, hand brush. You could use a power tool one but most are steel and only brass plated, you would have to find a 100% soft brass wheel and use low rpm. Soft pure brass wheels in small sizes are not that common.
