Preferred gear oil for super 8.8 rear end.
I’m going to change my gear oil in my 2020 f150 I just purchased I am considering going amsoil but is it worth it, or is an off the shelf gear oil equal? Which would you go with? Thanks everyone!
I was never convinced that Amsoil is any better to justify its high cost. I would use an off the shelf gear which meets the needs stated in your manual for your differential type.. I have mostly used Supertech or whatever was cheapest in the past for my Ford's 8.8 differential.
Those super 8.8’s. come with 75w85, if you want to stick with the oem spec, however any 75w140 would serve you well. You won’t notice any measurable fuel economy loss.
If you haven’t made a change yet
Wait for the results that SubieRubyRoo will post soon. Lots of info to pick from
