My 2003 BMW 330Ci has an auto trans with a fluid cooler at the bottom of the radiator. It also has a coolant temp sensor in the bottom radiator hose. My OBDII software allows recording data, here is an hour drive from April of this year. Outside temp was about 72. Data is trimmed down to every minute, the recorded data has about 700 datapoints per minute.
Code:
Time Engine Vehicle Coolant Coolant Ignition Injection Oil Temp
Speed Speed Engine Outlet Timing Duration
07:24:31.625 0 0 91 86 7.7 0 92
07:25:00.343 930 0 94 86 -11.1 7.28 92
07:26:00.015 797 5 120 86 -2.1 4.27 95
07:27:00.031 729 0 144 86 3 4.51 105
07:28:00.000 2345 58 164 86 24.8 8.26 119
07:29:00.000 2180 58 184 86 28.4 4.98 138
07:30:00.015 1784 51 191 87 28.7 1.9 155
07:31:00.109 1830 50 194 90 26.8 4.24 166
07:32:00.046 1897 51 195 101 28.7 3.72 175
07:33:00.343 2178 42 194 109 22.5 8.06 179
07:34:00.171 1720 47 195 117 27.6 2.76 188
07:35:00.000 1738 47 198 118 26.8 3.94 192
07:36:00.031 1697 47 198 118 26.4 3.78 196
07:37:00.031 1737 47 196 124 26.8 3.77 201
07:38:00.000 1629 41 198 122 22.1 6.14 204
07:39:00.312 1905 53 196 129 28.7 3.8 205
07:40:00.281 1910 52 198 125 25.6 5.04 206
07:41:00.437 2745 59 190 175 7.3 10.97 209
07:41:00.484 2745 59 190 175 7.3 10.97 209
07:42:00.421 2309 65 183 157 26.8 6.76 211
07:43:00.000 1923 52 195 124 29.1 3.8 211
07:44:00.015 1922 50 196 126 28.4 4.06 211
07:45:00.000 1245 39 198 126 -12.7 1.57 212
07:46:00.015 1850 52 198 136 25.6 4.73 212
07:47:00.125 2006 55 194 137 29.5 4.01 214
07:48:00.359 1869 55 196 130 28 1.47 214
07:49:00.406 1640 39 195 124 22.5 5.29 214
07:50:00.015 1496 30 195 156 25.2 2.66 212
07:51:00.000 755 0 199 149 13.9 3.96 211
07:52:00.000 1778 48 194 152 28 2.82 216
07:53:00.000 2117 58 186 168 29.9 3.9 216
07:54:00.000 2094 58 195 124 28.4 4.76 214
07:55:00.328 2270 65 188 156 29.5 4.3 216
07:56:00.375 2029 55 195 128 27.6 4.58 216
07:57:00.000 2285 63 196 137 29.1 4.61 216
07:58:00.031 2312 64 195 138 29.5 4.21 216
07:59:00.015 2326 64 195 144 28 5.77 218
08:00:00.359 2426 69 195 140 17.4 11.03 218
08:01:00.343 2515 71 183 164 28.7 5.74 218
08:02:00.281 2236 67 191 136 -4.5 1 216
08:03:00.015 966 24 196 117 2.6 2.13 212
08:04:00.203 696 0 202 125 5.7 3.51 211
08:05:00.125 2593 74 183 180 31.9 4 218
08:06:00.296 2593 74 192 136 29.5 5.14 216
08:07:00.015 2539 72 198 134 29.5 4.54 218
08:08:00.156 2549 72 196 134 29.5 4.74 218
08:09:00.203 2534 72 196 133 31.9 1.84 218
08:10:00.140 2524 72 196 134 29.5 4.61 219
08:11:00.312 2548 73 196 133 29.5 4.81 218
08:12:00.015 2454 71 198 138 31.5 1.68 219
08:13:00.031 2445 70 198 138 22.1 7.1 219
08:14:00.000 2465 71 198 137 32.7 2.45 219
08:15:00.437 1673 44 195 128 26.8 3.55 218
08:16:00.015 2483 71 183 182 -2.1 1 218
08:17:00.359 705 0 182 157 4.5 3.53 214
08:18:00.031 701 0 200 138 4.1 3.62 212
08:19:00.296 703 0 203 151 4.5 3.62 212
08:20:00.343 2542 72 191 190 29.9 4.51 218
08:21:00.000 2464 70 184 164 26.4 5.99 218
08:22:00.078 2121 58 195 125 28.4 4.53 216
08:23:00.359 2132 59 198 133 29.9 4.06 216
08:24:00.218 2137 59 198 140 28.7 4.23 218
08:25:00.015 2541 73 186 173 21.7 6.32 218
08:26:00.015 2544 73 195 136 28.4 5.38 218
08:27:00.031 2554 73 196 136 26 6.16 219
08:28:00.093 2546 73 198 141 29.1 4.68 219
08:29:00.437 2517 71 196 138 29.5 4.54 219
08:30:00.015 2532 72 198 140 30.3 4.34 222
08:31:00.265 2194 63 198 136 28 5.02 219
08:32:00.000 702 0 202 141 4.1 3.61 216
08:33:00.015 1975 17 202 173 24.8 4.35 218
08:34:00.203 721 0 204 169 3.7 2.6 218
08:34:20.687 698 0 204 167 5.3 2.62 218
The car has a ECU controlled thermostat, when the engine coolant temp drops to the mid 180s above, it is after I hit over 3000 rpm. The ECU seems to cool the engine down to about 180 when the load / engine speed increases. It runs about 200 with the cruise set, low load conditions.
Code:
