Predator 4000 watt generator 212cc not working after extended storage
This generator has been sitting in the shed for who knows how long. My ex claims it worked last time his dad used it, but that could have been 3-5 years ago.
I drained the gas by disconnecting the hose at the output of the fuel on/off valve and put new Trufuel 4 cycle gas in. There was a little old gas left but not much.
I also drained most of the oil and put some random leftover 10w-30 in.
Anyway, it doesn't work. If I take the air filter out and squirt starting fluid in it'll stay running but as soon as I stop spraying the starting fluid it dies.
I have come to the conclusion that the motor itself and the ignition system are at least mostly functional, but I don't know where to take it from here.
I did notice the choke seemed to work because in the start position it would run OK on the starting fluid and in run position it sounded quite grumpy even while spraying the starting fluid.
The carb is likely clogged with varnish. Usually takes several years to form like that.
