Originally Posted By: tig1
Just what is the size of 1PPM when it comes to metal PPM in a UOA?
It's Parts Per Million and that doesn't reflect size, just volume. The gas spectrometer tests used to give you the PPM number only "sees" small particles, typically around 5 microns or smaller. If you do a particle count, you'll see particles lots larger. I had a count done on one of my tractor engines as well as a "normal" UOA. Here are some of the results to contrast:
IH D358 diesel, 8197 hrs and almost 100 hrs on the oil
Iron- 13 ppm
Chrome- 1.3 ppm
Lead- 1 ppm
copper- 1 ppm
Aluminum- 13 ppm
Those are the wear metals "high spots" and in looking at them, you's say whoa, that engine is doing great, yet look at the actual particle count:
4-6u- 20,699,202
6-14u- 2,869,403
14-21u- 46,838
21-38u- 1,695
0 count for anything larger
ISO code: 25/22/16
I have seen only a few other tests where both a UOA and an optical particle count were done, and they were similar, but I really don't know if this is a typical picture of a UOA. I find it interesting that the oil filter used has an absolute rating of around 21u and that's where the particle count really drops off.
So, if this is a normal UOA snapshot, then there is a lot more going on than a single UOA is going to tell you. I imagine the people who can accurately interpret wear metals have seen the particle counts along with the spectrometer results and know what's truly "normal." When I think that most internal engine wear comes from the range from 10-20u, I'd want to filter a little better in that range.
