1995 Toyota Corolla 1.6L with automatic transmission. Build in Jul/Aug 1995.
Found a leak in the power steering pressure hose on the metal crimp, from the pump to the steering rack/column. If you turn the steering in the parking lot when the engine is on, you can see some weeping from the crimp. Fluid was sprayed everywhere under the hood, and would rather replace all the hoses instead of just use a stop leak product (want to keep this car for long term, mom can't drive anything but a corolla as it is easier to drive).
Now there are 2 types of hoses according to Rockauto and Gates. One is with Inverted flare fitting, the other with O-Ring. AC Delco (more trust worthy as GM also makes the Prizm) has only the O-Ring fitting one.
So can I assume that it is the O-Ring fitting?
