For the longest time, I refused to recommend or perform power steering flushes. This was because power steering fluid is not an OEM specified maintenance item and it lives a fairly easy life since it is hydraulic fluid. Furthermore, if there was a component failure, the repair cost is fairly low (compared to ABS components or a powertrain component) so the ROI would be difficult to justify. After all, the intent of maintenance is purely for the purpose of reducing operating costs, not increase them.
I have a customer with a 2013 Mazda 3 with 80k miles. It uses an electrically operated power steering pump. For years, the pump has always had a somewhat noticeable high pitched whine. I chalked it up as normal operation since it started occurring at a very low mileage, never got louder and the system was working fine.
During the last service visit, I decided to flush the p/s fluid to see if the noise would be reduced. Per the repair manual, the system holds 1.1 qt of fluid. So I disconnected the rubber line located south of the electric power steering pump. With the engine off, I rotated the steering wheel several times. Then I buttoned everything back up, refilled, and bled the system. This replaced about 3/4 qt of fluid, which is pretty good. I then repeated the process once more. I used Idemitsu Type M ATF from WorldPac.
As you can see in the picture above, the fluid is now clean. It was dark brown before. Best of all, the noise from the pump is SIGNIFICANTLY reduced. It is probably 80% quieter.
I may have to reconsider my position on power steering flushes. I have always viewed them as wallet flushes, but this experience has caused me to reconsider.
