Hello everyone. GREAST site...wow !!
My '05 Impala (3.4 v/6) 45,000 miles. The past bad cold spell in chicagoland was not good.
I was not getting heat inside and coolant looked a bit icy. All of that was repaired and such but the power steering pump made a bad groan/moan when 1st started up in the cold snap,looked like honey it was so thick w/air bubbles. I tried sucking some out with a turkey baster (that works well) then adding fresh fluid with brand name fluids, NEVER cheap-o stuff. It got a bit better noise wise and the color turned a lighter shade, not the ultra dark color it was. Now that the weather is better the moan/groan is much better but you still hear it on turning. I see many p/s fluids that claim this and that...is there a better fluid that may help besides the basic p/s fluid? Or do I just need to buckle down and get a new pump with lines flushed? Steering fells a bit light then it tightens up to what I call a normal feel.
Had a new water pump and thermostat (gm stat) installed along with fresh coolant (they flushed/replaced it in may of 2011!). Shop is highly reguarded as very good from tons of folks. Sorry...long winded but ya got information. I try to do prevent maintenance but that cold spell hurt everyone in the area. THANKS !!
