Power steering fluid as jack oil
Ohio
Giving a little TLC to an old bottle jack that dad kept in the trunk of the Lincoln. Might be a little weird to have a sentimental attachment to a bottle jack, but anyway... I was thinking about changing the oil in it as it's got to be at least 60 years old. Coincidentally, I have a mostly full bottle of Honda power steering fluid that no longer has any use. Any problems with that?
Depends as i've seen jack oil be as little 13cst kv40 which makes 0w-8 look thick in comparison and as thick as 50 cst kv40. In case you need to use that jack in bitter cold temps stick to the thin stuff. Bars jack oil is good thin stuff that walmart carries for a decent price. Thicker stuff like that Honda Power Steering Fluid is fine if it won't be used in the cold. Those old ones are easy to rebuild in case the seals are bad.
PS fluid should be fantastic in a jack I would think.
My personal use has been an assortment of fluids from bar & chain, gear / transmission / ATF, engine oil but never hydraulic as I don't usually have any.
While it's not exactly apples to apples, Dex/Merc lifts at least one vehicle per day on my Bendpak ;) I've actually been using the Valvoline "Import MultiVehicle" because I have a leak and got a bunch of the Valvoline cheap
The type of oil is not what does the lifting. The only factor I see is seal compatibility
IMO as long as the fluid will flow, not freeze, lubricate, and not destroy seals.......I say give it a shot.
Thanks all, Hazard Freight has jack oil, I'll just pick up a bottle. Seals are probably compatible with Honda Power Steering Fluid, but.... It does get used.
Picked up a bottle of jack oil from HF, and the oil in this old timer was a pretty nasty. Making out what's left of the label it's a Hein-Werner 1.5 ton. I'm guessing it's from the 1960s.
