First off, do you think it's worth changing.
Second:
My manual says use Nissan or an equivalent which it says could be Dexron3/Mercon or an equivalent ATF. It doesn't list Nissan Matic D as an equivalent.
However, under auto transmission in the manual it says Dexron3/Mercon or equivalent is ok.
So it doesn't specifically say I can use the Nissan Matic as power steering fluid, yet the equivalents they list for each fluid type match.
Do you think I can use the Nissan Matic as power steering fluid? The reason I ask is because they only sell power steering fluid in small bottles and it would be cheaper to get the bigger bottle the Matic D comes in.
Anyone know how much I'll need? I don't know how much the Nissan takes Sentra Takes. It's an '01 SE.
Thanks
