If it is failing, not much you can really do. I have had success with fixing some leaking and noisy power steering racks with the Valvoline MaxLife Power Steering fluid. They were not on Asian cars though.
My Tacoma had a steering issue a while back. It pulsated anytime the was moderate load while turning (i.e. slow turns or turning while not moving). I did nothing more than a complete fluid exchange by pulling the return hose and adding new fluid while cycling the wheel. 100% improvement and that has been 5+ years ago. Not sure if the replacement fluid(brand) really matters but it's worth a try and fairly cheap.
What does that even mean? There are half a dozen issues that could effect power steering. If it feels like BOTH are failing at the same time, could be something external. Maybe you just need to replace the belt tensioner that's causing the belt to slip.
