I sent an email to my local power company (Northern Virginia Electric Cooperative) about whether they are still installing them on air conditioners and what the benefits of having one installed are and this is what they said:
"Hello Brian: Yes we install load management switches on electric water
heaters and air conditioners. There is really two benefits to having the
switch. One is that they help us in keeping our cost down associated with
peak demand, that is it helps us to stabilize our rates from going up. By
having it on your air conditioner, we will do a first call response to a no
cooling call from you. We will send out a technician to check the switch and
diagnose your air conditioning problem, there by saving you the cost for
having a contractor come out and charge you for that time to figure out what
the problem is. If it is a loose wire or a fuse we will replace it for free.
There is no cost to this program. If the problem is more than a loose wire
or fuse, you can either have our contractor fix it for you or call your own
contractor."
I am most interested in the part about keeping costs associated with peak demand down. Because this is an electric cooperative, any money they save comes back to me as a credit on my electric bill, in addition to not having rates go up.
I think this is a good idea, and I'm going to get it installed on my air conditioner.
EDIT: The switch is controlled by a radio signal, much like a pager. In fact I think the signal is almost identical to a pager.
contractor."
