- Joined
- Feb 28, 2010
- Messages
- 1,663
Hello Everyone.
I am interested in purchasing a MOTIVE Power Bleeder for my car and had some questions. There seems to be a couple of ways in which folks utilize this "Bleeder" and what BITOG members opinion on which they would do.
1. Utilize the power bleeder as a "Pump" only. Do not fill with Brake Fluid and install a quick connector on the hose going to the Brake reservoir. Suck out as much old fluid, fill with new, screw on the cap, pressurize bleed, disconnect the quick connector, unscrew the cap, refill and repeat basically till all four are done.
2. Fill the Bleeder with fluid, pump it and basically keep an eye on the pressure and fluid level in the bleeder until all 4 are done.
#2 is the way the manufacturer recommends. It seems #1 way is easier in the way that you dont have to clean out the Bleeder and such. I just want to do the easiest, but best for the car way. Not the best because I am lazy way. Which way would you guys and gals do this...#1 or #2?
Thank You for your time...
Jeff
Jeff
