Post your latest small engine oil change
My push mowers.....
Toro Briggs 5HP -- Rotella synthetic 5W-40
Honda 6.75HP -- Rotella synthetic 5W-40
Craftsman 3.5HP Briggs -- Rotella synthetic 5W-40
JD JX75 6 hp Kawasaki and SCAG 36" 13 hp Kawasaki KAI V-twin both got RP MaxCycle 10w30 w/ K&N HP-1003 filter.
Toro SR4 mower (B&S L head)- Amsoil ACD
Simplicity Coronet RER (Kohler Command)- Amsoil ACD
B&S Elite 3.5kw generator (B&S Intek)- Amsoil ACD (SSO or GC in Winter)
JD 1032 snow-blower (Tecumseh Snow King L head)- GC or Amsoil SSO
Stihl FS80 string trimmer- Amsoil 100:1 Saber premix
Stihl O31AV chain saw- Amsoil 100:1 Saber premix
Napa Synthetic 5W30 in an old 7.5HP Tecumseh snow blower engine that just got put away for the summer.
Briggs 14.5hp OHV Gold Series, 1.5 Qts Super Tech 10w30
Briggs 12.5hp Gold Flathead, 1.5Qts Super Tech 10w30
My sisters is getting done soon,
24?HP Briggs AVS (pressure lube), Super Tech 10w30 Dino, Supertech or Briggs filter.
Husqvarna Lawn Tractor Kawasaki V twin - Shell Formula 10W40
Craftsman Lawn Tractor Honda GX V twin - Shell Formula 10W40
KLR650 Dual Purpose motorcycle - Shell Rotella T 15W40
Suzuki 500cc Liquid cooled ATV engine - Shell Rotella T 15W40
Simplicity snow thrower B&S Kool Bore - Mobile 1 synth. 5W30
Old rototiller 2.5 h.p. B&S engine - whatever is left over.
Old Craftsman 3.5 h.p. Tecumseh push mower - as above.
That's it for this half of the year.
Yesterday, April 13 2010: 3 yr old 48" cut Sears w/hydro trans, 24 HP Briggs V-twin. Drained old oil(Rotella 15w40, had about 30 hrs on it, looked OK) & removed old filter. Refilled with Chevron Delo 15w40, & installed a red textured Advance Auto Suregrip? 3614 filter. Also installed a freshly serviced air filter & pre-cleaner. Plus removed & cleaned deck, installed a new set of Gator blades, & greased fittings on jackshaft spindles.
Today did much mowing. 8^P
Lawn mower- 5 hp B&S
Pressure washer- 5.5 HP B&S
Garden tiller- 5 hp B&S
Lawn tractor- 18.5 hp B&S
Lawn tractor #2- 24 hp B&S V-Twin
Real tractor- 47 hp 4-cyl Branson diesel
All get 15w40 Rotella & OEM filters once a year
I just put 20 oz. of a 4:1:1 mix of ATF, SeaFoam, and MMO in the crankcase of an old snapper edger that I found on the side of the road this evening. She ran pretty well after a new sparkplug and gas tank. Tomorrow, I'm going to let it get up to operating temperature, then drain the mix and refill with some RTS.
The other edger I found has the same mix in the crankcase, but it is seized up. The combustion chamber is filled up and soaking, too. It's a mix that's worked for me in the past.
