Post your latest oil change
2003 Toyota Corolla:
Out - Valvoline Restore and Protect 5w30/ Supertech Filter.
In- Valvoline Restore and Protect 5w30/ Premium Guard Filter.
271,006 miles. About 4500 miles on this fill.
What went in was the third interval of this oil. So far to date, the oil consumption of about 3/4 to 1 qt per 5,000 remains the same. 9500 mi total on VRP. Very early on into the first interval, a startup noise after sitting was eliminated, likely due to the timing chain tensioner solenoid being dirty. Very pleased so far, hoping this or the 4th oil change will start reducing oil consumption, although I can live with it.
I’d use VRP for the remainder of this cars life. It clearly deserves it and you will be the beneficiary!
I read it as the poster is a traveling tech who was called to change the oil on the truck. Probably doesn't know the OCI, or care about the mileage.
Argos is the Advance house brand. Was probably there for the filter and picked up what was cheap.
2021 Toyota RAV4, XLE, 2.5L
83k on vehicle
4,510 oci; 2-1/2 months (Road trip to Niagara Falls, then back to NC, then to San Antonio TX and back to NC)
Out: 4.5 Qt Castrol EDGE 0W20 / Fram Ultra XG4967
In: 4.5 Qt Castrol EDGE 5W20 / Premium Guard PG4476EX
No 0W20 in stock at local WM
Premium Guard filter donated by a very kind and generous BITOG member.
2008 Honda Civic, 1.8L (Daughter's)
170k on vehicle
5k oci; 8 months
Out / In the same: 4 Qt VRP 5W30 / OEM filter (15400-RTA-003, Japan made)
Installed Valvo-Max drain kit. Aluminum pan threads were sketchy. I tapped them, flushed 1/2 Qt of clean oil through, let sit a week, then installed Valvo-Max with Loc-Tite thread sealer, let sit another week before dumping oil in.
24' Nissan Rogue SV
Mobil 1 Hybrid with OE filter out and same went back.
Oil change interval 6 months (4,772 miles) saved some mileage with the car being in the body shop for deer damages and had a loaner for the rear glass recall-replacement.
Just not worth filling the hotdog compressor to set tire pressure and was able to try out the new 1/2 torque wrench. I may have been overfilled a tad pulled out 4.5 liters which is 4.75 Qts or we have fuel dilution maybe but I tell you the oil never smells like fuel. Rode around the block let the car sit 10 minutes and I am full on 4 Quarts. Will put some miles on tomorrow and recheck.
