Post your latest oil change
2021 Crosstrek Sport, 54146 miles. Last oil change on 05Jun2025 @48410 miles. Miles on oil = 5736.
1. Out: Castrol Edge Extended Performance 5w30 and Fram Ultra XG7317 oil filter.
2. In: The same but from single quart bottles.
2021 Crosstrek Sport, 60278 miles. Last oil change on 03Dec2025 @54146 miles. Miles on oil = 6132.
  1. Out: See quoted post.
  2. In: Castrol Extended Performance 5W-30 plus 300 mL LiquiMoly MoS2
  3. Oil filter: Subaru (Tokyo Roki 15208AA21A) and new crush washer.
  4. Extra: Replaced original drive belt with Continental 4060755 belt.
2019 accord sport 2.0t 99k on odo
Out: Valvoline Restore and Protect 5w30 and champ PH2867xl 4,196 miles on oil
In: Valvoline Extended Protection Synthetic 5w30 and champ PH2867 xl
Scored some autozone closeout deals on the Valvoline Extended Protection so figured I’d run it. Plan on running this 4k as well.
2009 new to the family Honda Pilot with 3.5 liter V-6.
Out unknown black oil at 146,000 miles. Castrol jobber filter with pale white ADBV. When I pulled off the filter, no oil drained back from the galleries.
In: 4.3 liters Pennzoil Ultra Platinum 5W30.
Napa Gold 7356 filter. It’s a PG filter. It measures 2.5 “ in diameter and is 3.5 "long.
The drain plug was torqued way too high and so was the oil filter. Luckily, I was able to get the filter off with an old filter wrench that was really too large but contorted enough to get a bite. A new wrench will be ordered soon.
The clearance to get to the dipstick and oil fill hole is ridiculously tight. I had to place a funnel in the hole and then place another funnel feeding into it. Also, I used a flexible oil thingy to keep the oil from draining directly onto a crossmember.
Enjoy the pics.
The drain plug was torqued way too high and luckily I was able to get the filter off with an old filter wrench that was really too large but contorted enough to get a bite. A new wrench will be ordered soon.
Enjoy the pics.
There’s a long/slender gray funnel I’ve got that works great for these 3.5 Honda J series engines. I’ll try to find a link, but you’ll know it when you see it. No need for a two filter setup like you had to improvise. Yikes about what you pulled off. Nice job on the oil/filter.
I use this when an oil or transmission fill hole is in a wingnutty place:
https://a.co/d/0cuDffXE
Did the annual oil/filter change on my Challenger today. Went old school and removed/cleaned the splash shield and drained the plug rather than using the top-sider. Added some 3 year old Mobil 1 with a Mobil 1 filter. All went well, but going back to the MityVac next year. It’s just too easy. Although, the splash shield really needed a cleaning.
'93 C1500 5.7l 170k miles
Out: 5qts Mobil 1 5w40 and Bosch filter, 3k on oil
In: 5qts Delvac 1300 10w30 and Fram orange cans from AAP clearances.
'05 Element 269k miles
Out: 4qts Valvoline Restore and Protect 5w30 topped off w 1qt Havoline Pro-RS 0w20, 4500 miles on oil, Ecogard X4610 filter.
In: 5qts Valvoline Restore and Protect 5w30 w Ecogard X4610 filter
Wasn’t that Havoline Pro-RS the plant based oil Chevron contracted out from a 3rd party (don’t recall companies name)?
Red brick garage floor that's awesome but must be a pain.
