2019 Toyota Camry XSE 2.5L (Performed on 07/20/22) Toyota brand synthetic 0W16 and Toyota oil filter
Cool funnel! Are you running a VCM disabler? One pretty much saved my niece's Oddy.2012 Honda Odyssey
141,604 miles
OCI: approx 5.5k
OUT: Quaker State High Mileage 0W20, Wix 57356
IN: Castrol Edge 0W20, Fram PH7317
It is an expensive ($25) funnel but makes things easier! And yes, VCM has been disabled since about 40k.Cool funnel! Are you running a VCM disabler? One pretty much saved my niece's Oddy.
I am totally gonna get one of those funnels. I found a "ABN no spill funnel" on amazon for $17. (Appears to be the same one as OEMtools for $27) The Hyundai is a pita to use a regular funnel on.It is an expensive ($25) funnel but makes things easier! And yes, VCM has been disabled since about 40k.
Cheers!
The Oddy oil pour location is bad; I use a skinney funnel and pour slow. This funnel might be worth it.I am totally gonna get one of those funnels. I found a "ABN no spill funnel" on amazon for $17. (Appears to be the same one as OEMtools for $27) The Hyundai is a pita to use a regular funnel on.
On the new Hyundai's they have a plate just inside the valve cover, I guess to keep debris from falling in ,it's difficult to get a regular funnel in there. You gotta pour it with one hand and juggle the funnel with the other. Like you say ,then pour it slow. Hopefully it works out. I already ordered the ABN no spill.The Oddy oil pour location is bad; I use a skinney funnel and pour slow. This funnel might be worth it.
Probably more for keeping oil from flying out the oil fill hole if the engine is ran with the cap off.On the new Hyundai's they have a plate just inside the valve cover, I guess to keep debris from falling in ...
