Post your latest oil change
2016 Honda Civic LX Sedan - 2.0L K20C2 , 6 sp manual
Mileage on vehicle : 36,680
OCI - 5,806 miles / 9 months
OLM at 20%
Out : 4.5 qts of Quaker State Ultimate Durability 0W-20
In: 4.5 qts of Pennzoil Ultra Platium 5w30
Did not change the oil filter - running the Fram XG7317 for one more OCI - 3rd run on the filter.
2004 Jeep Grand Cherokee 4.7
In: Pennzoil Ultra Platinum 5w30, Fram Ultra XG16.
Out: Bulk fill conventional 5w30 from a local garage, done by previous owner, plus about 1/2 quart makeup oil, Pennzoil Platinum HM 5w30. Also, there was a cheap bulk generic oil filter.
This engine will be happier with the good stuff in it.
106,500 miles on her. We'll be going with a 5k OCI on this run.
11 Silverado
Out: OReilly FS and Champion filter
In: Mobil Super Synthetic and Delco
6,200 miles on the OReillys FS and filter
Same day:
2002 Suburban 277k-change once a year
Out: SuperTech 5w30 w/Supertech filter
In: SuperTech 5w30 w/Supertech filter
Its probably had this combo for the last 150k
2012 4runner 130k on truck-I dont really pay attention to the mileage as it only sees about 16-18k a year. I just change it every November and May. I run the 0w30 in summer purely for mental reasons, and then 0w-20 over the winter. Never put a drop of make up oil in this truck.
Out: Mobil 1 0w30 Extended Performance
In: Mobil 1 0w-20 Extended Performance
I use either K&N or Toyota filter. Never done a used oil analysis, but this combo seems OK. The EP is only $2 more for 5 qts at Walmart than AFE. I figure Im good for 8-9k with an oil advertised for 15k.
...The EP is only $2 more for 5 qts at Walmart than AFE. I figure Im good for 8-9k with an oil advertised for 15k.
Is that Super Tech syn or conv?
You could probably use vanilla M1 for 8-9k.
Sorry the post may have been confusing. Im running vanilla Super Tech 5w30 in the Suburban. The 4runner is what Im using the Mobil 1 Extended Performance in. I just use the EP because its only $28 for 5 qt vs the AFE for $26. I havent actually looked at the price of vanilla M1.
1971 Dodge D200 Camper Special, 318 c.i. V8, NP435 4-speed manual. 31,500 miles on engine, unknown miles on vehicle.
Out: Unknown, Luber Finer PH8A. Unknown time/miles on oil.
In: 5 quarts Harvest King 10w30 Conventional, Purolator L30001.
2002 Ford F-150, 4.6L 2V V8, M5OD 5-speed manual. ~60,000 miles on engine, 226k miles on vehicle.
Out: Harvest King 10w30 Conventional, CarQuest R85372. Less than 1k/about 6 months on oil. Changed due to fuel dilution. Stuck injector.
In: 6 quarts Harvest King 10w30 Conventional, Prime Guard POF4651.
2011 Camry LE 4 banger from Hertz sales.
Belongs to my late father's wonderful neighbor, Edna. She's over 90 and a great lady.
Only driven the car about 2,300 miles since July 2018.
Out - almost 5 quarts M1 or Valvoline 0w20 synthetic. Whatever I had on hand...
In - almost 5 quarts Super Tech 0w20; left Fram UG.
Aired up tires to 35 PSI all around. Car sits a lot...
2012 Honda Civic LX 87,575 miles. Mobil 1 0W-20 Mobil 1 oil filter. I changed it a little early because it was a nice day and I should be good to go for a while.
I changed the automatic transmission fluid and did a drain and fill with the recommended Honda ATF. I also installed a new magnetic oil plug.
Ford 2018 3.5L Ecoboost
Out 5w30 M1 Full Synthetic, Valvoline Filter
In Pennzoil Platinum Pure Plus 5w30, Fram Tough Guard filter
2016 Lexus RX350
Out Mobil 1 bulk 0W-20 from Toyota dealership
In Mobil 1 Advanced Fuel Economy 0w20 5qts.+ 3/4 qt. Supertech 0W-20 FS
Toyota OEM filter
Just bought the Lexus from a Toyota dealership. May have had 5000-6000 miles on the existing oil... hard to tell from the windshield OCI sticker. I wanted my own baseline.
Set the OCI to 8500 vs Lexus spec of 10,000 miles.
17 Sportage
Out: RP 5w30, Carquest premium filter
In: Pennzoil Conventional 5w20, ServiceChamp at the closest JiffyLube location. Got a $13 off coupon and decided to give it a try, probably not anymore
04 Avalanche Z71 4X4. 136k miles
Out: 5w30 Mobil 1, Mobil 1 oil filter
In: 5qts Mobil 1 High Mileage, 1 qt Mobil 1 all 5w30 from stash K&N oil filter
[Linked Image]
1976 Oldsmobile 350V8 in an 84 Cutlass ~230k miles on body
Engine unknown mileage 100k miles put on since 2007.
Out: Castrol syntec 10w30 with about 2k miles mostly short trips over a few months. This oil was 10 year old stock in my dad's stash. I wanted to put fresh oil in right when I store it for winter but I was beyond my 6 month comfort zone for short trips with a carburetor.
Mobil 1 Extended Performance filter was also on for the last two fills (basically the whole summer).
In:
Mobil 1 High mileage 5w30
Ac Delco filter (because I bought the wrong Mobil 1 filter and realized when I saw the part number on the old one as I took it off. So I borrowed a filter from my friends stash.
This is I think the first high mileage oil I've ran in this engine. I guess I consider it high mileage now that it's 12 years and 100k miles since I pulled it from the junkyard and put a timing chain, valve seals and some gaskets in it. I'm hoping high mileage oil will prevent the 12 years old rear main seal and valve seals etc from hardening up and leaking. So far no leaks.
2011 Camry, 72k, one year 9k on oil.
Out and in: Pennzoil Ultra 5w20 Fram Ultra.
2017 4runner, 52k, one year 7k on oil.
Out: TGMO 0w20 Toyota Filter.
In: Castrol Magnatec 0w20, Toyota Filter.
