Post your latest oil change
2018 Jeep Wrangler JL, 3.6 Pentastar Gen 2, exactly 22,000 miles
Out: Pennzoil Ultra Platinum 0w20, about 5200 miles on it, Fram Ultra filter.
In: Mobil 1 Annual Protection 0w20, Mobil 1 filter. I'm planning on 5k, but may go longer.
$12 rebate on the Mobil 1 Annual Protection oil, so 25 bucks for 5 quarts, and the Mobil 1 filter was $4 on clearance at Walmart.
2016 Porsche 981
9334 miles
Out Mobil 1 0w40 and OEM filter
In Castrol 0w40 and Napa gold 1348
Changed @ 1 year
2016 3500HD LML Duramax
45,922 (3,149.9 engine hours)
7,823 miles (591.8 engine hours) OLM=0%
Out: Traveller 15w40 (CK-4), Rotella RTO-59
In: Same
I also did a transmission pan drain and changed the spin-on transmission filter and cleaned the magnet. Refilled with 7.4 quarts of Dex 6. Transfer case fluid also changed with Dexron VI.
In: Same
Well you saved a ton of money over the Stealership purge and fill on the transmission didn't you.
In: Same
That's a lot of idle engine hours. My 2005 Silverado work truck has almost 200k miles and well over 8000 engine hours. It spends a lot of time idling with AC or heat on, most of its life working for our land surveying company.
The LML is my dads truck, It's a farm truck that does a lot of low speed driving and short trips. It does have some idling mixed in here and there, but the majority of the hours are from the low speed driving. I've been just following the OLM but I feel like it's going a little too long given the use it sees. I might do a used oil analysis sometime after running the OLM to 0% and see what it looks like.
Some of the 2019 L5P Duramax's were having OLM problems (counting down too quickly) and the bulletin below is the recommendation from GM. 7,500 miles, 300 engine hours, or once per year.
[Linked Image]
[Linked Image]
2013 civic ex 5spd. Quaker State Ultimate Durability 0W20 and orange cod 7317.
Out: Castrol edge 0W20 and Mahle filter.
I've had good results with all of the above.
Before this, I tried Supertech 0W16 as an experiment and it worked great, improving mpg by 1.3! No metal shavings on my magnetic drain plug and no abnormal oil burning off. Will do again on next change!
1972 Dodge Polara
1973 440, second oil change after freshen up
awhile back, has mild Mopar Performance flat tappet cam and matching valve springs
Out: Mobil Delvac 15w40, old white/blue Purolator from their good reputation era
In:
-3 quarts of 18 year old NOS SJ pre-Brad Penn green dyed Kendall GT1 SAE 40
-3 quarts of SM Formula Shell 5w20 to thin it a bit
-1 pint of SLOB additive to help the FS
Maybe I'm crazy for doing this but have done it many times before with no issues. In the end, it's close enough to 30 weight.....
2010 F-150 5.4L 3v V8, ~42,000 miles on truck, 5,000 mile OCI
Out: Unknown Dealer Oil, Motorcraft Fl-820s Filter
In: 5 Quarts Castrol Magnatec 5w-20 and 2 Quarts Pennzoil Platinum 5w-20, NAPA Gold 1372
On most vehicles I run a 5,000 mile conventional oil OCI, but with this truck I believe Ford recommends a 5,000 mile OCI when using a synthetic oil. I usually do 7,500 miles with a synthetic, but I will stick to what Ford recommends because the 5.4L 3v are known for engine issues. If this were my own truck I would use 5w30.
2018 KIA Sportage LX AWD
Out: Castrol EDGE 5w30, PH9688
In: Pennzoil Platinum 5W-20, PH9688
Drove to the Keys today. A total of 300 miles. I must admit, I understand the fervor for Pennzoil Platinum now. This is by far the quietest, smoothest oil I've used yet.
Originally Posted by Red91
I had and used some sj Kendall gt1 straight 30 a few years ago. It was a pleasant nostalgia trip that I thoroughly enjoyed.
How did it taste?
