Post your latest oil change
1985 Toyota Corolla LE, 4A-LC engine
Previous oil & filter: 3.5 qt TGMO 0W-20 SN & Mobil 1 M1-103 @ 266,485.4 mi, Sunday, April 30, 2017, 7:00 pm, ~ 80 °F
New oil & filter: 3.58 qt (2.55 oz extra for larger oil filter) Mobil 1 Extended Performance 0W-20 SN PLUS & Fram Ultra XG3600 @ 272,206.1 mi, Sunday, February 24, 2019, 6:00 pm, ~ 57 °F
OCI: 5,720.7 mi, 665 d
New Toyota 90430-12031 drain-plug gasket every time
2013 F-150 with 82,010 miles on the clock. 7,713 miles on this OCI.
Out: Pennzoil Platinum 5W-20 and Wix 57502
In: Pennzoil Platinum 5W20 and Wix 57502
Originally Posted by chunt
2018 Rogue with 14K. 6 month, 4K OCI
Out: Pennzoil Platinum 0w20 & TG7317
In: Quaker State Ultimate Durability 0W20 & ST6607
$14.40 OC
How did you do so cheap?!
In: Quaker State Ultimate Durability 0W20 & Super Tech6607
$14.40 OC
Quaker State Ultimate Durability on sale and with rebate with $3 Super Tech filter
05 focus wagon
2.0 4 banger
Out: unknown, supertech filter
In: Napa 5/20, Napa gold filter
18 CR-V
2.4 4 banger
Out: unknown, Honda filter
In: Mobil super syn dexos 0/20, Napa gold filter
14 transit 150
3.7 v6
Out: havoline 5/20, mighty filter
In: acdelco 5/20, Napa gold filter
Another one yesterday.
OCI: 5500 miles (500 overdue)
Oil in: PP High mileage 5w30
Oil out: same
Filter in: Mobil 1 Extended Performance
Filter out: Purolator Boss (run 10500 miles)
Vehicle: 99' Ford Explorer 4.0L OHV @ 241541miles
Oil added between intervals: up to 0.5 qts
2017 Toyota Corolla LE
Out, Nissan Exxon 0w20 full synthetic w/ Purolator One
In, NAPA 0w20 full synthetic w/ NAPA Gold
6 months oci
On my 2003 Mach 1, the cap spec's 5W20. I did oil analysis on it when I bought it at 128,000 miles. It was a one owner meticulously cared for car that he used Ford spec's on for maintenance. I then switched it to 5W30 and have been running that over the past year. Oil analysis looks better with lower wear metals and slightly better viscosity numbers at operating temp. By the numbers, I could even go to a 5W40 and it would be perfect. So like most cars that spec watery oils these days for CAFE reasons, the engine actually likes higher viscosity better it seems.
So:
5W30 Motorcraft oil
Motorcraft oil filter
Car will hit 140,000 miles this year and still runs very strong.
15 Subaru outback
2.5 flat 4
Out: some sort of Valvoline 0/20, service champ filter
16 Silverado 1500
5.3 v8
Out: unknown, Napa gold filter
In: acdelco syn dexos 0/20, Napa gold filter
‘18 Hyundai Santa Fe Sport 2.4
OUT
AMSOIL Signature Series 0w20, hyundia 26300 35504
IN
AMSOIL Signature Series 0w30, ea15k20
'05 Toyota Matrix 151k
OUT
Valvoline 5w20, Ecogard filter, 5700 miles over 4 months.
IN
Pennzoil 5w30, Pennzoil filter, much smoother and quieter now.
OUT
IN
Did the 5w20 seem to use more than the usual top off oil in your OCI?
The reason I ask is I have some Castrol Gold Jug 0w20 I'm planning to use in my Toyota in my Oct/Nov OCI next fall.
No, not at all but it was conventional oil. That was my 4th interval with that oil. It did seem to consume a good half quart over 5k with Motorcraft syn-blend 5w20. The engine does seem more peppy with the 20 wt oil. I have some Pennzoil Ultra Platium 5w20 and some Idemitsu 0w20 to use up also for next fall/winter. I think your Corolla will do just fine with the 20 wt.
So:
5W30 Motorcraft oil
Watery oil?? Didn't know oil had water in it these days.
You failed to tell us what kind of Ford you have.
2008 Mazda Miata
Mobil 1 5w-20
Fram Ultra Synthetic
I have not changed my oil myself but had others do it and was sold on a vacuum oil extractor. No bueno on getting the extractor tube to the bottom of the oil sump. My drain nut was put on by some gorilla and had to use a cheat bar to loosen it and the alumimun crush washer was as thin as can metal.
Really? At least the extractor can be used to transport the oil to Pep Boys.
