Post your latest oil change
Originally Posted By: Bud_One
Co-workers truck -changed during lunch break.
2005 Chevy Silverado 1500 Ext Cab 5.3L V8
Mileage on vehicle - exactly 135,000
OCI - over 2 yrs and unknown mileage
Out - Bulk Dealer Oil (5W30?) and Jobber white filter with smeared red writing
In - 6 qts 10W30 Chevron Supreme with AC Delco PF61E
Any make-up added?
How many quarts did you drain?
Any make-up added?
He stated he'd put in at least two quarts from what he can recall. Drained about 4.5 qts out - it was low . Found that the oil filter wasn't even hand tight , I barely touched it and it started coming off.
Out:
At about 4750 miles, a witch's brew of synthetics and conventional oils I got on sale, with a Pure One filter that I wanted to be rid of at 5000 miles or so. I was tired of thinking about Purolator filter tear issues. I will not use Purolators any more.
In:
M1-102 filter.
Oil is a mix of Mobil 0W-40 synthetic, Supertech 30W, Supertech 20W-50, Castrol Edge 5W-50, and some Toyota 5W-15.
2015 F150 4x4 2.7L Ecoboost
2,074 Miles on Factory Fill (Strong Gas Odor to Oil)
6 Qt of Pennzoil Gold Synthetic Blend w/ Dexos Label
Motorcraft FL2062
2104 Harley
16139 miles on bike
6100 on oil
Out HD 20w50 and a Purolator filter
In Valvoline 20w50 and a Motorcraft filter
2011 Ford F150 with 3.5 Ecoboost
Out: Mobil 1 Advanced Fuel Economy 0W30 and Motorcraft FL500S
In: Mobil 1 Advanced Fuel Economy 0W30 and Motorcraft FL500S
wifes 06 Freestyle
out Valvoline Hi Mileage 5w20 & motorcraft FL829
in Valvoline High Mileage Synthetic 5w30 ( free oil) and a bosch 3410 filter
sample taken for lab
My new to me 03 Neon
Out: Fram orange can and whatever bulk oil from Canadian Tire
In: Napa Proselect and Quaker State Conventional 5w30
2006 Dodge Ram 3500 SRW, Cummins 5.9 turbo diesel, rebuilt engine fall of 2015.
out: Rotella T 15w40, NAPA Gold filter, 4999.5 km OCI, 7 months
in: Rotella T 15w40, Fleetguard Stratapore LF16035
wife's 12 civic, supertech syn 5/20 bosch filter. 8563 miles OLM at 15%
04 cummins, Travellers 15w40, donaldson 7349 filter. (stinks like rotella does) out was valvoline 5w40 EPB @ 7502 miles.
Ah, the lovely Rotella stink. Makes you know you're got fresh oil.
Tonight
Gator Tail 35 Vanguard Marine (Briggs and Stratton) mud motor
2.5 quarts Delvac 15W40, Fram Ultra 3614 filter, 50 hr intervals between oil and filter changes
also changed oil in transmission, 10-12 pumps of Delvac 15W40 from a squirt can, 50 hr intervals also
greased all fittings
Ready to go juglining tomorrow night
2011 Ford Fiesta SE, 1.6L I-4 w/manual trans.
70,202 miles on vehicle - 6,330 miles on oil
OUT:
Castrol EDGE Full Synthetic 5W-20, FRAM Tough Guard
IN:
Mobil 1 Extended Performance 5W-20, Purolator BOSS
Also replaced Purolator Classic air filter with another Classic air filter.
My engine seems very very noticeably more quiet after the oil change. I believe the oil is possibly shearing down, hence why I went with Extended Performance. I'm thinking it may be a bit more shear stable but I should have checked with a used oil analysis to confirm. The reason I think it's shearing is the engine seems noticeably more noisy as an oil change goes on & I run very high RPM. 3K-4K RPM for long periods at 70-80mph on the highway, downshifts to pull hills at high speed reving to 5K & beyond plus I regularly redline at 6K just for the heck of it even though it's a slow car.
2006 Hustler Z zero turn mower
23hp Kawasaki
56hrs approximately
Out: Rotella T 15w40
In: Same
Left the Fram TG on for one more oci
2013 Honda Rancher 420
45hrs approximately
In: Same
Changed oil filter with Honda OE.
OUT:
IN:
In other words.....you drive the dog snot out of it.
OUT:
IN:
Not quite that bad, but it sees redline once a day anyway. Lol As for the high RPM on the interstate, not my fault Ford didn't give it a 6th gear. Haha
2004 Ford Ranger 4L V6. Miles: 150,432
Out: Mobil Super 5000 5w30 and AC Delco PF1250. No startup rattle was observed with this combo. OCI/FCI 4900 miles. No makeup oil added. I cut the filter open. Everything was in order.
In: MC Premium synthetic blend 5W30 and WIX 51372. It took maybe 3 seconds to fill the filter and galleries. As noted from the startup rattle ceasing. I think I will fill the filter next time.
Just did a change on my 1989 Chevy Suburban V2500 with the 350; decided on using SuperTech conventional 5w30 and try out a SuperTech filter since I see they are once again a decent design from Wix.
When I changed the oil last time, I used 10W30 as I had that laying around along with a Baldwin filter I got from a truck stop and I noticed the engine just was sluggish at times, which I attribute to the oil.
