Post your latest oil change
2009 Pontiac G8 GT 6.0
Out: Mobil 1 5w30
ACDelco PF48
In: 7qts Mobil 1 5w30
1qt Pennzoil Platinum 5w30
1qt GM Dexos 5w30
Baldwin B160
06 Mustang 4.0
Out: Valvoline 5w30 conventional + MC fl 820s
In: Mobil 1 0w30 + Mobil 1 210
Cleaned K&N, replaced cabin filter
When I got Kitacamry it had been run with conventional 5w30...to 97.5k miles...and at most, 10k OCIs...
@ 100k (a 3k conventional OCI) I switched to Pennzoil Platinum (PP) syn 5w30 until it ran down to "0"...after 5.6k miles
....during that OCI Kitacam seemed to burn more oil on the highway (@75-80mph) than in town...just a bit more, but still noticeably...but still, it went 5.6k on 1 quart....
In this 2nd OCI with PP/K+N filter, oil dropped from 1/8" above the letter "F" to the F-line after 1k primarily local street use...then I took to the highway for a 3.5k mile trip (1400 each way on the highway running a constant 70-80mph for 8-10 hours each day of the 2-day run) and when I got home the dipstick level is surprisingly STILL more than half-way up from "0"
sooo...in this 2nd PP/syn OCI Kitacamry has thus far used less than a half-quart after 4.5k miles....
2013 Mazda 3 skyactiv, 12835 mi.
Out: unknown dealer 0w-20, Mazda filter
In: Mobil 1 0w-20, Mazda filter
1995 Dodge Ram 1500 4X4
Out: Pennzoil Conventional 10w30, Purolator Classic L14670
In: Pennzoil Conventional 5w30, Purolator Classic L14670
2000 Buick LeSabre Custom
October 20, 2013
Mileage 114,708
Drained Out .... Valvoline MaxLife 10w30 with AC Delco PF47
Poured In ........ Mobil Super 5000 10w30 with AC Delco PF47
2004 Hyundai Santa Fe
89,032 exact miles
Freakin' sweet ride with leather interior and sunroof (just thought I'd throw that in there)
Out : 4 qts Valvoline "Next Gen" 10w40
In : 4 qts Pennzoil Platinum 5w30
Same filter used - a Wix 5331
I have a 2001 f-150 4.6 super crew. 215,000 miles on motor. i use motorcraft filter 820 and Pennzoil 5w30. motor does not use oil between changes. i change oil every 4,000 miles. The one time I used a different brand oil filter(wix), my oil pressure gauge fluctuated while going down the road. Went back to motorcraft. no further problems.
peotis
2006 Chrysler T&C 3.3
Out: 10w30 Valvoline Next Gen Con, Wix filter 5k miles
In: 5w30 Pennzoil Ultra, Fram Ultra
2006 Prius, 108771 miles.
Out: Mobil 1 Extended Performance 5w30, Napa Gold Filter. 7600 miles and 10 months.
In: Valvoline SynPower 5w30, Fram TG4967 filter.
The oil level was 3/4 qt low...
Originally Posted By: Zaedock
2013 Ram C/V Tradesman 3.6L 8707 miles
Out: Factory fill and filter @8707 miles
In: Amsoil 5W20 OE Syn and Puro filter
Great choice!!
2001 Honda CR-V 2.0L, 94,500 miles
Out: Valvoline MaxLife Blend 5w30
In: 50/50 mix of Mobil 1 0W-40 and NAPA Full Synthetic 0W-20, Honda A02 filter.
