Post your latest oil change
Got tired of the oil change routine, so I let my local Honda dealer do it:
4 quarts QS 5W-20 and a Honda A02 filter.
2000 Dodge Dakota 4.7 123,000K
Six quarts of Pennzoil 5w-30 SN GF-5
D3500 Bosch Distance Plus filter
2001 Ford F150
-6.25 qts Red Line 5W-20
-8 qts Red Line D4
-Motorcraft FL-820S
153,9xx miles at change, went on a trip to NC last week and already have 2,000 miles on it.
1996 Ford Taurus Wagon 3.0 OHV
5 quarts Mobil Clean 5000
1 pint Marvel Mystery Oil
Motorcraft Fl-400s filter
1993 Ford Taurus SHO 3.2 DOHC 5 speed
6 quarts Mobil 1 0w-40
Mobil 1 301 oil filter
3 quarts ATF+4 AAP brand trans fluid for the gearbox
I had to drill a trap my trans case for a drain plug, FORD forgot to add one from the factory on this model trans it seems..... so next oil change I'll probably change it out again now that its so easy to do.... might try redline atf or M1 atf.
Expect same oils/filters on next OCI for both cars in the engine department.
1988 Chevrolet K1500 Truck
Oil:
5 Quarts Valvoline Maxlife 10W-30
Fram Tough Guard Oil Filter
Transmission:
2 Quarts Pennzoil Synchromesh
Transfer Case:
3 Quarts Valvoline Dexron III
Diffs will have to wait until another day.
Dodge Ram 04 5.7 hemi 102K. 5 quarts of m1 0w30 AFE and 4.5 quarts of M1 EP. Oci was 7,755k on RP 5w30. Oversized M1 EP filter.
Did the Fall service on two of the cars this weekend.
2000 GM 4.3 Vortec, PU 5W30 and Ecore Filter.
Walmart was out of PP 5W30 (the usual fill) in the 5 Qt jug and PU was "only" $1.50 more at $25. Wasn't it about a year ago that I could get PP for $18? All the 5 Qt jug prices were up significanly.
2000 Ford 3.0 Duratech, Motorcraft semisyn 5W20 and MC filter.
Motorcraft is now up to $14 for the jug. Only about 9 months ago I think it was $11.
1991 Buick Century 3.3L
4.8Qts of Vavoline Max Life 10W30 Syn-blend
AC Delco PH47E oil filter.
199,898 Miles at the time of change.
Changed every 5K miles, or one month. (5 kmiles a month avg..)
