Post your latest oil change
Hey Phil, another Mobil 1 0w40 oil change here :)
2003 VW Jetta TDI (with moderate mods)
115,000 miles
Mobil 1 0w40 (4.75 quarts)
Hengst oil filter (Mobil doesn't make oil filters for my engine
2007 Toyota Rav4 V6.
19,500 miles on odometer
6 quarts Pennzoil Platinum 5W30
STP cartridge filter
2005 Ford Taurus 3.0 V6 Duratec---
43,789 miles
Mobil 1 5w30
Bosch 3422 Oil Filter
(99.9% PO clone)
2004 X3 2.5
88,599 miles
7 quarts Mobil 1 Turbo Diesel Truck 5w40
BMW OEM filter
And tomorrow...
1999 Jeep Wrangler Sahara
107,000 miles
6 quarts Mobil 1 10w30
Mobil 1 filter
43,789 miles
Mobil 1 5w30
(99.9% PO clone)
A friend has a 2000 Taurus with the Duratech and now has 308,000 miles using the Mobil 1 5w30. It's been a great engine and transmission for him.
Saturday 1/2/10 Castrol Syntec Blend 5w30 in the 4.6 GT w/PureOne Filter
November 09 Castrol Full Synthetic 5w50 in the Shelby w/Motorcraft filter
Originally Posted By: KeithKman
Originally Posted By: Bill in Utah
With 3k OCIs I'd run any 5w30 and see if your oil leaks go away.
The engine will be protected and last just as long with Pennzoil conventional as it would be with PP or Mobil 1.
The oil companies will not be as well protected though....
Follow the OLM since you have one. 3k OCIs are really a waste of resources in my book...
Take care, Bill
Oh, I understand. There is actually a service bulletin on the 5.3 motors for leaking oil pan gaskets and the oil cooler lines. I'm not worried about it at all. I'll be getting it fixed Monday. The leak is super small.
Ended up being a blown rear main seal and rear cover gasket leak. $553 to fix.
43,789 miles
Mobil 1 5w30
(99.9% PO clone)
I'm really surprised, I thought those transmissions were very trouble prone? Is the transmission with the Duratec different than the one with the Vulcan?
Originally Posted By: ernied
2009 hyundai santa fe 14000 miles
Valvoline durablend 5/20.
hope its a good oil for this suv.
Excellent oil!
No worries....
93 Aerostar 179,500 miles Pennzoil High Mileage 5w30 Pennzoil Conventional 5w20 50/50 mix. 300 ml Lubro-Moly. AAP Red filter.
43,789 miles
Mobil 1 5w30
(99.9% PO clone)
It is a different transmission. Although Ford did make changes in 1998 with the Vulcan transmission that made a big differance in durability.
2001 Toyota Camry 5S-FE 64k Mobil Clean 5000 5w30, Supertech ST4967
1999 Camry 5S-FE 147k Mobil Clean 5000 5w30, STP S4967
2002 Ford Taurus 3.0L 24v Duratec
113,500 miles
2 qts 5w-20 QS Torque Power Syn
4 qts 10w30 QS Torque Power Syn
Motorcraft FL-820S filter
27 degrees out.....no wind.
2002 GMC Sierra 4.3l manual transmission. 127k
3k on the oil, used for some heavy towing and lots of high rpm activity. Used a ST3980 ecore. Used Chevron Supreme
Replaced with Valvoline W/B 5w30 and a AcDelco Champ non-Ecore Pf52.
