Post your latest oil change
2001 Ford Focus ZETEC
6k miles on oil valvoline wb 5-20, with a fl400s motorcraft
replaced with
motorcraft semi syn 5-20 and another motorcraft filter.
96k miles total on car.
also did front brake pads and replaced rotors
Second oil change for a 2010 Civic LX Sedan. Drained PYB 5w20 and replaced it with Mobil Clean 5000 5w20 that was recently on sale at Advance Auto for $2.49qt. I know the 5qt at Wally World is cheaper but I prefer the quart jugs. The MC 5000 has the bigger opening and when putting a funnel in it it does not tip over like the smaller openings on other brands when pouring the used oil back into the jugs.
2000 Camry LE, 5s-fe, with 130,XXX K miles
OUT: PYB with PureOne filter @ ~3000miles
IN: Valvoline MaxLife Blend (5quart jub@$13.5 Wally World roll back) with PureOne ($5 @AAP).
I wonder can I if I can go with 5000miles OCI. Or should I just go with 4000miles.
2009 Chevrolet Silverado 4.8L V-8; @ 9350 miles on odometer; bulk Valvoline conventional 5W-30 x 5 qts w/ Super Tech synthetic 5W-30 x 1 qt; Valvoline brand filter; too cold to do planned oil change using MotorCraft syn blend 5W-30 x 6 qts & AC Delco PF48 filter (Champion Labs)
Changed Sept 12 2010
05 camry - 2.4L 2AZ-FE
90,000km total
7,500km on oil
Shell Semi Synthetic 10w-30
4.3 liters
Toyota OEM Filter
1997 Toyota 4Runner Limited 2WD
Engine: 5VZ-FE 3.4L V6
6 quarts Castrol Syntec 0W-30 Euro formula (GC)
K&N HP-1002
2005 Ford Freestyle - 77,725 miles
Red Line 5W-20 - 6 quarts
Motorcraft FL-820S
2001 Ford Taurus 3.0L Duratech DOHC V6
Last service - November 4th / 101,500 miles:
4.5 qts. MC 5w20
1 qt. MMO
SuperTech ST2
Yesterday's service - December 31 / 105,000 miles:
3 qts. M1 AFE 0w20 (that's all I could find at 2 different WM's)
2.5 qts. PP 5w20 (left over stash)
MC FL-820S
2001 Ford Focus 2.0 Zetec 5-Speed 168,801 miles.
Out=Royal Purple 5W-30 Motorcraft FL-400S Filter.
In==Royal Purple 5W-30 K&N HP-1012 Filter.
2000 Dodge Dakota 3.9 Magnum 5-Speed 123,311 miles.
Out=Royal Purple 5W-30 K&N HP-2004 Filter.
In==Royal Purple 5W-30 K&N HP-2004 Filter.
