Post your latest oil change
2004 Toyota Highlander 2.4 - 109,820mi
Previous OCI: 4 Quarts PP 5w30; OEM Filter
Recent OCI: 4.2 Quarts Chevron Supreme; Napa Gold 1396
**used up the last of my CS stock from when I got it for less than $1 per quart.
I will probably get and use PYB from now on in my vehicles unless I find a killer deal to stock up on.
2007 Ford F-150(brother's);
-7 qts Schaeffer's 5w20
-Motorcraft FL820-S filter
55,700 miles.
1998 Ford Escort(brother's gf's);
-2 qts QS 5w20/2 qts QS 10w40
-Supertech 3600 filter
175,000 miles.
Recently change two of mine, one to go...
2003 Mercury Marauder, Mobil-1 0W-40 & Motorcraft FL-828s filter
1998 Mercury Grand Marquis, Castrol Blend 5W-30, Motorcraft FL-828s filter
(one previous owner, 39K mi)
Originally Posted By: Kaboomba
1995 Sable: 2 qts Mobil1 EP 5W-30 + 24 OZ Shaeffer's EP Moly + 2.3 qts MMO + PureOne PL24011
Is that a typo? I like MMO, but 45.5% of capacity is alot!
The EP moly should offset some of the thinning, but you're a bold man!
The engine had been sitting for over a year, and was swapped into the Sable after getting new top-end gaskets and rod bearings.
FWIW, the ol 3.8L Essex is running great on that cocktail, smooth and with little noise (less than usual for a 135K Ford 3.8L).
