Just bought a 2018 Ram with the Hemi. Manual calls for 5W-20. How's the 0W-40 working out? Any lifter tick?2018 ram 1500 5.7 hemi, 85,500 miles 7500 on oil
Out: mobil 1 fs 0w40 and a wix 57899xp
In: mobil 1 fs 0w40 and a wix 57899xp
Working out great for me! My 2018 got 5w20 from new til about 54k. No lifter tick just trying to prevent it i guess whether it does or not time will tell. Mds seems to be working fine with the 0w40 as well. No check engine lightsJust bought a 2018 Ram with the Hemi. Manual calls for 5W-20. How's the 0W-40 working out? Any lifter tick?
Are you using the micron moly mineral oil or the supreme 7000 synthetic blend? Just curious. Schaeffers makes some good stuff.1973 MGB:
Out; Schaeffers 20w/50, Bosch Platinum filter
In; Schaeffers 20w/50, Bosch Platinum filter
Hey, stick with what works! And with gas prices the way they are I'll be driving it more once the snow melts because I get between 26 and 31 MPG!
It's the Supreme 7000. Extra ZDDP.Are you using the micron moly mineral oil or the supreme 7000 synthetic blend? Just curious. Schaeffers makes some good stuff.
2011 Subaru Forester FB25 2.5L 3800 miles on oil
Out: AMSOIL Signature Series 0w40 Tokyo-Roki oil filter
In: AMSOIL Signature Series 0w40 Tokyo-Roki oil filter
View attachment 91981View attachment 91982
Yes, no lower engine cover to remove.Envious and jealous of the location of the oil filter .![]()
Speaking of lower engine covers what use do they serve but to making DIY more of a pain where you sit?Yes, no lower engine cover to remove.![]()
They cut down on engine noise and keep the underside of the engine very clean. On my 2002 Subaru Forester the oil pan has no surface rust. So, they do help but can be an inconvenience to remove and install.Speaking of lower engine covers what use do they serve but to making DIY more of a pain where you sit?
They give a tiny increase in gas mileage by smoothing out the air flow under the carSpeaking of lower engine covers what use do they serve but to making DIY more of a pain where you sit?
whew...2011 Subaru Forester FB25 2.5L 3800 miles on oil
